Car is jerking and knocking when accelerating
This happens when I'm slowing down through a town or stuck on the interstate in heavy traffic (coasting basically) without stopping and then depress the accelerator. The car jerks and you can hear it knock, it's worse when running the A/C, but happens without it. Sometimes feels like it could stall but doesn't.
Runs fine cruisin on the highway, only happens at low speeds. If anyone has a clue I'd be grateful!!
Hooked up to VAG but didn't find anything, here's the results:
VAG-COM Version: Release 404.0-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR AT D03
Coding: 06251
Shop #: WSC 06335
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans
Controller: 8D0 927 156 BQ
Component: AG5 01V 2.8l5V USA 8511
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D00
Coding: 0273004284
Shop #: BB 24334
Address 08: Auto HVAC
Controller: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04162
Shop #: WSC 06335
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 919 910 P
Component: B5-KOMBIINSTR. VDO D05
Coding: 02262
Shop #: WSC 00000
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump D10
Coding: 16140
Shop #: WSC 06335
7 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
Address 56: Radio
Controller: 4B0 035 186 A
Component: Radio D02
Coding: 00113
Shop #: WSC 06335
End --------------------------------------------------------------------------------------------------
Address 01: Engine
Coding: 06251
Shop #: WSC 06335
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
Coding: 0273004284
Shop #: BB 24334
Coding: 04162
Shop #: WSC 06335
Coding: 02262
Shop #: WSC 00000
Coding: 16140
Shop #: WSC 06335
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00101
Shop #: WSC 06335
Address 56: Radio
Coding: 00113
Shop #: WSC 06335
OA 69
06-15-2007 06:27 PM
WECoyote-SuperGenius
09-10-2006 12:40 PM
Roger @ CA
Mid Atlantic Discussion
06-19-2005 09:57 AM
