Car sits higher in front then rear
I own a 1997 A4Q, and one of my friends told me that my car sits lower in the rear then the front. I didnt believe him so I measured...Sure enough, the rear was 10 inches of ground, the front was 12. I had a six inch gap on the front from wheel well to tire, and 2-3 inch on rear. My shocks feel fine, I can take corners quick and it seems to handle fine. I took it to a local shop, and they couldnt find anything. I called Audi and the told me to bring it in. Problem is, they are over 100miles away? Anyone run into this problem?
should be 27" front and 26.5" rear or there about. measure all four. my car went a little odd at 150K. iirc it was the front struts getting longer.
That is a huge wheel gap though. Front is probably around 28.5-29 if his first info is correct.
I will have to mesure tomorrow, kinda dark now. All i know is it looks odd.
suspension with vogtland bilstein combo and the rear still sat about .75 inches lower.
My current car has Eibach and koni combo and the rear sits about .5 inches lower. (inch or two lower than that if I have 3 others in the car). But a 2 inch difference unloaded isnt normal.
