Car Stalling, Need Advice Please (Longish)........
My 98 A4 1.8t Tip is stalling at idle, and off throttle while at speed. The check engine light is not coming on. So far I have taken it to a shop where they found a fault code with the MAF. It was not replaced. Instead, they cleaned out the intake system and throttle body. Car is idling better, but stalled again today. It starts back up after stalling again with no malfunction lights.
Should I replace or clean the MAF, or should I be looking at the throttle body (ISV valve)? Thanks for any input.
Also, we don't have a dealer in my area.
And it was to the threshhold of stalling, it wouldve thrown a light.
I would look for what we think are minor vacuum and intake leaks around the vac lines..
When the maf is going bad the g/s get lower, when that happens the #'s get so low during idle and when you let off the throttle fast. The maf then tells the ecu to cut the fuel to adjust for the low air flow.
Still getting the 17549 - Load Calculation Cross Check: Implausible Value P1141 - 35-10 - - - Interm
Kris Hansen
06-24-2008 05:41 PM
BTCC A4
03-27-2004 12:02 PM
