car is still stalling at idle though. the revs bounce up and down and sometimes they go too low and
blocks 015 and 016 are misfire counters... and there will be a misfire DTC BEFORE the CEL comes on...
you need to get your hands on a VAG bro...
I had this same problem. What was happening was that the MAF was reading correclty but the air was never registering into the TB. It was trying to fool the car into having air flow when it wasnt and it tries to die out. Its like your trying to keep the thing alive with the gas pedal but it doenst help.
It could be many things. Now that you have got the red flag, take it to Autozone(if you have one in the area). They will diagnose a check engine light for nothing. It will tell you exactly what the problem is. Most of the time thier equipment wont read the description, it will come up Manufacturer Specific trouble code but it will give you the code and then you can look it up<ul><li><a href="http://www.bentleypublishers.com/tech/audi/dtc.table.htm">Here..</a></li></ul>
I had the same problem. The connection into the turbo compressor had a massive leak, so the MAF was in an unstable feedback loop. If I could get the car started it ran ok, but getting the car started was pretty much impossible.
Good Luck, Ian
Good Luck, Ian
bA8
05-29-2007 02:40 PM
thermo
Audi Original "S" Cars
03-30-2006 05:01 AM
