Car very difficult to get into gear [physical pressure on shifter] --> bad throwout bearing?
Old 12-17-2008, 02:03 PM
pentosinjunky's Avatar
Default Car very difficult to get into gear [physical pressure on shifter] --> bad throwout bearing?
Starting my car off in first is very difficult; second is marginally easier; third and fourth, at appropriate speeds, are OK. I think the throwout bearing might be bad [vs. a 4Ok-old O34 pressure plate being bad]
When coming to a stop with the car still in first or second, the engine feels as if it wants to stall; IE, the clutch is not totally disengaging.
Are these symptoms of a bad throwout bearing?
Old 12-17-2008, 02:23 PM
Member
chris w/ a b5 1.8t's Avatar
Default clutch adjustment perhaps? might not be disengaging all the way
throwout bearing going bad sounds like bad clutch chatter when disengaging the clutch. (usually)
maybe it can cause this, not really sure.. way back before i got my hands dirty with this car i had a similar problem.. where it was pretty tough to get it into first after the car had sat (like overnight). took it to my shop and they "adjusted the clutch" and it was fixed.
maybe someone more knowledgeable can elaborate. apparently it was a simple procedure.
Old 12-17-2008, 02:49 PM
Romaudi's Avatar
How do you adjust clutch?
Old 12-17-2008, 02:50 PM
Tech Guru
4Driver4's Avatar
Default Hydraulic issue? How does the pedal feel?
Try bleeding it?
Old 12-17-2008, 03:16 PM
AudiMick's Avatar
It's not adjustable.
Old 12-17-2008, 03:17 PM
Member
Default like i admitted in the post, this was before i started working on the car..
a shop i took the car to "adjusted the clutch"
I fully admit i dont know what they did. Apparently it was simple.
I dont have alot of experience with manuals.
Old 12-17-2008, 03:56 PM
bhz1's Avatar
Default My '96 had been having the same problem with 1st...
intermittently. Currently at the shop to be picked up tomorrow. Supposedly it needed 2 tranny mounts and was low on trans fluid. Clutch, while releasing quite high, was not slipping. Not bad for 173,000 miles.
Old 12-17-2008, 04:55 PM
AudiWorld Expert
Reggie's Avatar
Check level but I suspect the slave cylinder is going
Old 12-17-2008, 05:05 PM
ski ya later's Avatar
Not TO bearing. Check fluid, clutch master & slave.
Old 12-17-2008, 06:12 PM
velosouljah's Avatar
Default Don't rule out the linkage adjustment. My sedan was getting harder and harder over time
even after I changed the fluid. Ended up being just linkage adjustment of that one 6mm bolt under the boot. Over time it got shifted slightly to the right and bringing it back to the left made all the difference in the world for putting it into 1st and shifting into 2nd.
HTH...
Quick Reply: Car very difficult to get into gear [physical pressure on shifter] --> bad throwout bearing?
