CARSON! Or, for that matter, anyone. Would a Bently help here?
Guest
Posts: n/a
Weird. These are the tranny codes I get:
2 DTCs Found:
17101 - Transmission Input Speed Sensor (G182): No Signal
35-00 - -
00652 - Gear Monitoring / Trans. Range Controller
27-10 - Implausible Signal - Intermittent
I only get these after I shift out of third. IOW, up to the shift point in third I am perfect.
Shift into fourth, either via Tip mode or let it be automagic, and input speed drops to nuttin.
Car freewheels till it stops, but I get first gear engagement after that.
Can you help me figure out how to diag this?
Does a Bently manual have the trackdown for codes?
2 DTCs Found:
35-00 - -
<center><img src="http://pictureposter.audiworld.com/66020/dtc_00652.jpg"></center><p>
<img src="http://pictureposter.audiworld.com/66020/dtc_00652-1.jpg">
<img src="http://pictureposter.audiworld.com/66020/dtc_00652-2.jpg">
<img src="http://pictureposter.audiworld.com/66020/dtc_00652-3.jpg">
<img src="http://pictureposter.audiworld.com/66020/17101-1.jpg">
<img src="http://pictureposter.audiworld.com/66020/17101-2.jpg">
<img src="http://pictureposter.audiworld.com/66020/17101-3.jpg">
<img src="http://pictureposter.audiworld.com/66020/17101-4.jpg">
Guest
Posts: n/a
So I guess first I get underneath and drop the pan, as no matter what it is overdue for service.
I know I had a water intrusion issue with the connector for the range selector switch at one point, I guess I will need to take that part and check it.
Anyone know where all the connectors are on the tranny?
It's a bummer they put all tranny codes into images: searching for them yields nothing; you have to scroll through the whole trans OBD chapter :-(
Omski
13
12-31-2006 12:58 PM
Christian A.
02-25-1999 12:01 PM
