Carson is that part number '8D0-853-959-B-01C' for the lower black trim circled in the pic?
I can't find much on how to get them on or off online and in Bentley. Do they just pop on/off? Also what about the last little piece that goes on the back wheel well?
<A HREF="http://www.trademotion.com/partlocator/index.cfm?action=searchCatalogOEM&siteid=215021">< IMG SRC="http://pictureposter.audiworld.com/138208/lower_door_mouldings_edit.jpg"></A>
the plastic replacement clips? if you have metal ones you should replace them, they are cheap.
are perfect except the missing one. Wish I knew what came with the strip from Carson. As it stands right now I've got mostly white plastic clips that are still intact on the door.
What I did wast cut up a MTB inner tube and stretched it over those clips so that it doesn't look hideous until I get the replacement. Actually from a glance you can't even tell ;-)
Anyone just get an individual piece from dealer or Carson and know what that comes with and the details to install it?
It didn't come with any clips. I think some are getting copnfused as there are two different styles. If you have the white plastic clips that are riveted to the door, all you need is the moulding. It has a metal track built into the backside and simply slides over those white clips. Just make sure they are all aligned, and it should slide right on, back to front. Once attached, there is a phillips head pan screw that keeps it from sliding on the front lower corner of the door. Difficulty = .05/10. IIRC, the moulding itself was under $30.
laying around gonna order one from him. But he has no pic on the web page for that part number so was hoping to have him confirm it was the correct part.
Audi1177777
Q5/SQ5 MKI (8R) Discussion
12-13-2015 02:09 PM
b5s402
03-18-2007 03:00 PM
egp320i
10-07-2005 05:51 AM
Anyone have a part number (or know how much and where to buy) that top trim piece around the hazards
esses
10
04-29-2003 09:04 PM
