CEL - P1296/17704 - Engine Coolant Temp Sensor Question.
My CEL came on and the code reads P1296/17704 which translates to 'Cooling System Malfunction.' In searching this forum, I found that this seems to be a common occurence and the fix is simply to replace the coolant temp sensor. However, in the description of the issue, many people have commented that the coolant temp gauge on their dashboard seems irratic. Mine doesnt seem to do that. So my questions are, does this code mainly signify a sensor error or is there anything else that can also be wrong? Anybody else have a similar issue?
Here is my experience, hope it helps.
The temp gauge never seemed erratic, however it never got to the 12 o'clock position (usually sitting between C and 12 o'clock).
The coolant light flashed here an there (once every two days on average).
No error codes were found.
Replaced blue square temp sensor for 16 bucks from ECS, all was well.
Good luck.
Good luck.
I had the same problem. Noticed same thing. Also after I reset the CEL and then drove again, just before / after the CEL came on again, you would notice the discrepencies in temperature read out.
Change the Temp Sensor and you'll be set.
it is really two sensors, one goes to the dash, the other to the ECM. Mine was intermittant, and I had the same experince as you, no indication on the dash.
golfindaily
10-10-2007 07:35 AM
Audi in MA
03-22-2005 08:22 AM
