Changed plugs, now occasional misfire, suggestions?
Old 08-11-2004, 07:50 AM
spdrcrpete's Avatar
Default Changed plugs, now occasional misfire, suggestions?
I put the NGK BKR7E-11 plugs in my car ('97 1.8TQ, K04/GIAC) over the weekend, gapped to 0.034. Now if I get into the throttle hard under 4000 RPM, I'll get a misfire or two before the RPM's get up. I probably should change the gap, but I don't know what to change it to. Searching the archives is what led me to 0.034 (most popular from what I read) Suggestions welcome.
BTW: The plugs I took out (trying to address surging issues at WOT) were bosch 4-prong platinums, that my mechanic 'thinks' he put in when the K04 went in. I think they're probably 30K miles old. They looked fine.
Old 08-11-2004, 07:52 AM
AudiWorld Expert
Digit@lex's Avatar
I gapped my BKR7Es to .032 with no issues
Old 08-11-2004, 08:09 AM
Junior Member
201-A4's Avatar
Default What was the original gap of the BKR7E?
They're 1 heat range colder that stock right?
I think that Im going to give the BKR7E's a try, because im having some misfire issues with the Bosch plugs Im running right now.
Old 08-11-2004, 08:12 AM
AudiWorld Expert
Reggie's Avatar
Default There is the possibility you damaged the spark plug wires
You can run a VAG and determine which cylinder is miss-firing.
Old 08-11-2004, 08:18 AM
Junior Member
201-A4's Avatar
no plug wires on a 1.8T
Old 08-11-2004, 08:26 AM
New Member
Audrenalin's Avatar
Whats the altitude where your at? Plug could be to cold with the gap.
Old 08-11-2004, 08:27 AM
AudiWorld Expert
Digit@lex's Avatar
I think the original gap was at .032. I just measure to make sure they weren't bent and pop them in.
Old 08-11-2004, 08:28 AM
AudiWorld Expert
Digit@lex's Avatar
Yes, they are 1 range colder.
Old 08-11-2004, 08:34 AM
spdrcrpete's Avatar
Outside of metro NY, so basicly sealevel-1500
Old 08-11-2004, 08:38 AM
spdrcrpete's Avatar
Default I'm thinking that .032 and .034 isn't much of a difference...
but I have several new sets of the plugs, so I can throw some in without re-gapping and see if it makes a difference.
Quick Reply: Changed plugs, now occasional misfire, suggestions?
