changing brake pads
The rear brakes include the parking brake. The parking brake pushes the piston out mechanically via a large screw. The screw allows the piston to come out as the pads wear. Most calipers of this type need to be pushed in while turning. It is usually not easy and there is definitely drag from the seals, but it works. I have done this with a pair of needle nose pliers, but the tools work better. Front pistons should just need a good push back into the caliper with a c-clamp.
Good luck,
Mark
Good luck,
Mark
Moe
11
02-18-2006 02:49 PM
quattro_silver
01-03-2004 05:56 PM
