Changing coolant tank, do I really need to flush the system?
Had the system flushed maybe 6 months ago. Just looking to replace my leaking coolant expansion tank and top off what's missing. Is a flush really necessary?
And what water do I mix the coolant with, distilled water?
Thanks
(96 2.8 12v)
Thanks
(96 2.8 12v)
Mix with distilled water as tap water has chemicals that can leave deposits in your cooling system.
How do you do it on AEB motor? The repair manual says to disconnect one of the lines that go to the heater core (just slide it out a bit) and a bleed hole will open. However, on my car the heater core lines are deep down below the firewall, - hard to get to from above. Is there an easier method?
on any engine, as long as the end of the tank hose remains above it's point of connection on the other end, bleeding would not be needed.
kingquattro05
10-13-2008 11:55 AM
Mr Paul [T-28]
12v V6 Discussion
11-20-2004 10:38 AM
BetterThanVW
01-14-2004 09:51 AM
Couper
10-04-2001 07:33 PM
