Changing my injectors today...any thoughts, concerns...
its pretty straight forward....I think there's 2 screws holding the fuel rail in and then it all just lifts out.Oh there's little clips that hold in the injectors. Have fun!
1. Before beginning, have towels ready to soak up the residual fuel leak;
2. (optional) spray a tiny little bit of WD-40 or other light lubricant into the area between the bottom fuel injector seal "O-ring" and the engine to make it easier to dislodge the injector;
3. When re-installing, lubricate "O-rings" with motor oil to prevent tearing;
4. When you re-start the engine check the fuel injectors for leaking at the "o-rings".
oyama
09-16-2011 07:51 PM
