Changing Tiptronic Fluid - Can't Seem To Find Info
I've searched every way I know how. I find plenty on changing manual trans. fluid, but nothing specifically for the Tiptronic. Since I really don't want to screw up the most expensive part of the car, I figured I would ask.
If it is the same procedure as the manual, just with a ATF fluid, then I'm good. Otherwise, is there any place I can find that info? And I am fully expecting to find it was located right under my nose the whole time.
Use this link the passat is virtually the same.
You can get OEM fluid for around $10 a quart from World Impex too.
-richard<ul><li><a href="http://www.taligentx.com/passat/maintenance/atfchange/">http://www.taligentx.com/passat/maintenance/atfchange/</a</li></ul>
I'd say it's find i didn't notice a difference. but with my new unit i'm not subbing anything.
-richard
-richard
1.5 - 2 hours max. Precedure is on Audipages, for an A8 same difference. However there is no interference with the V6 or the 4. With ambient temps at 80 degrees F it woudl reach 45 degrees C and just about maintain that temp indefinately.<ul><li><a href="http://www.audipages.com/Tech_Articles/auto_transmission/autotranservicing.html">Linky</a></li></ul>
Michaelmarco
A4 (B8 Platform) Discussion
08-16-2019 06:33 PM
JasoRosavo
08-04-2016 09:38 PM
TurboEnvy52
01-05-2005 01:45 PM
