is changing to xenon lights from halogen require only changing in bulbs?
More info..
A ballast is required to generate enough electricity to ignite the gas. The 12v battery alone cannot do it. It basically stores up enough juice to fire the bulb and then releases it (instantaneous action) It's a small sealed box you connect between the bulb and the power supply.
Think many people are confused about this issue. Xenon filled bulbs do not give you Xenon HID lights
HiTEC
05-11-2000 04:26 AM
