CHECK ENGINE LIGHT FOR P1128 (BANK 1 SYSTEM TO LEAN)
Check engine light for p1128 (bank 1 system to lean)
I RAN A VAGCOM ON IT AND THESE WERE THE RESULTS. IM NOT TO SURE WHERE THE PROBLEM WOULD BE EXACTLY THOUGH, I HAVE REPLACED THE FUEL FILTER, MASS AIR FLOW AND THAT DID NOT HELP. ANY HELP WOULD BE GREATLY APPRECIATED. THANKS
Address 01: Engine
Controller: 4B0 906 018 CH
Component: 1.8L R4/5VT G 0002
Coding: 16201
Shop #: WSC 63351
1 Fault Found:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
Readiness: 0010 1001
Address 01: Engine
Coding: 16201
Shop #: WSC 63351
1 Fault Found:
P1128 - 35-00 - -
https://www.audiworld.com/forums/sho...d.php?t=338539
https://www.audiworld.com/forums/sho...d.php?t=337551
https://www.audiworld.com/forums/sho...d.php?t=277237
Don't know if you tried searching yourself, but it's best to use the "advance search". There you put in a keyword(s), in this case P1128, select the forum you want to search on the right - B5, and then hit search. You should end up with about 4 pages to get additional ideas.
Hope this helps.
BTW, I would not use CAPS when posting or you are going to get flamed. Using caps is like yelling or screaming at someone. Just in case you didn't know.
Good Luck!
hec32
03-16-2013 09:58 PM
0000audi
VAG-COM Discussion
07-27-2005 11:49 AM
