Which chip will give me the most hp and touque?
Will it go on my a4?
How much does it cost compared to the wett?
right now i have the wett.
Will it give my 1.8t alot more power than the wett?
How much torque and horsepower does it give?
WHoever has one tell me how you like it
that averages 1 bar (mine peaks 18, drops off to 12 at high RPM). Anything over that works the stock turbo waaaay too hard, making it even more inefficient.
CHIPS.........
AMS(ABT): www.advancedmotorsport.com
Hoppen(MTM): www.hoppenmotorsport.com
Wetterauer: www.chip-tuning.com and www.wetterauer.de
TAP: www.tap1.com
Neuspeed: www.greedspeed.com and www.neuspeed.com
Garrett: www.giacusa.com/welcome.html
APR: www.goapr.com
Autothority: www.autothority.com
Autotech: www.autotech.com
Upsolute: www.upsolute.com/eng/index.html
TAP: www.tap1.com
APR: www.goapr.com
The stock turbo is only rated for 7 psi. After that it gets ineffecient and starts heating the air. The stock IC does a pretty good job of removing the extra heat though. Plus, the more boost you run, the higher the shaft speeds, that's why most chips cut back the boost at higher RPMs.
Odd Job
05-17-2000 07:25 PM
