claybar use question
I plan on spending the day washing and waxing my car. After washing I will be using a claybar for the first time. Do I wash the car again after using it? I will also be using 3Ms IHG followed by Blitz Wax.
DON'T waste the quick detailer. Mix in a spray bottle your car wash soap with water. Use 2x as much car wash soap as you'd normally use. Douse that over each section you clay bar and spray the bar REPEATEDLY (car and bar). Since its just soap, and it's cheap as hell, use a ton of it.
When yours done, just spray the car down with the hose.
You could do a really quick rewash, but I found it unnecessary when I did my car.
As I clay each panel (I also use soap solution as a lubricant), I'll follow with a soapy wash mitt to remove any residue that the clay leaves behind. If you've lubricated well, there shouldn't be any residue.
ATH
Auto Detailing Discussion
11
06-02-2004 04:43 AM
AUDIOZ A4
05-27-2002 06:59 AM
Longwolf (Christian)
02-08-2002 02:48 PM
