Climate control sensor function & VAG clarification needed
I STFA and couldn't find a clear answer on this so here goes:
My external temp sensor is shot. The dash display reads anywhere from -40 to 115 degrees at random. My A/C is intermittently blowing hot air. No real pattern to it, but I notice that sometimes the temp sensor is under 40 degrees when this happens (sometimes it's not).
I read that there is an intake temp sensor for the HVAC, a cabin temp sensor, and the temp sensor in the front bumper for outside air temp. I know the sensor at the front bumper is bad, possibly one other as well which I think may be causing the problem. Dealership parts guy is telling is telling me that the bumper sensor & cabin sensor are what is read by climate control unit (& could not confirm intake plenum sensor even exists). Others have said intake plenum temp sensor & cabin sensor are tied to the climate control. I have a few questions:
1) What sensor(s) are used by the climate control to determine output air temp?
2) Any suggestions to connecting my VAG to the Climate Control unit - I have not been able to successfully connect to that module (other modules are no problem) in order to read the outputs for the temp sensors. Would a battery disconnect make any difference?
3) I have 2 Part numbers:
8D0907539 - Dash Cabin Temp Sensor
4D0820539 - Front Bumper Temp Sensor
Anyone know the P/N for the sensor inthe HVAC intake plenum?
This what is what I have for p/n's
8D0907539 - SUNLOAD SENSOR/DASH TEMP SENSOR (this is the one that sits in the middle of your dash)
8D0820535 - outside temp sensor (the one in froint of the radiator)
4A0820539 or 4D0820539 - Inside temp sensor in plenum.
Check with the parts guys first.
You might also want to check with 1stVWParts.com, they are always cheaper for OEM than your local dealer.
4rings
20
10-22-2013 10:06 PM
DxC
12-14-2006 03:58 AM
YukonAudi
09-10-2004 04:31 PM
Jay Levitt
05-27-2004 03:10 PM
