Clunking coming from the rear differential (not mounts)
#23
So from what I gathered, the haldex system is basically a hydraulic locker for the rear end and requires a filter and fluid change every 30K miles. Problem is, it's on top of the diff and s bastard to get to. I think it was said in this thread that you can unplug a fuse to the system that'll help with the clunking.
#24
#25
Here is my experience with a clunk, in a nutshell:
Car:
1999 Audi A4 1.8t Quattro 5 spd
Symptoms:
Driveline clunk when engaging the clutch from a standstill, up / down shifting, and when lifting / applying the gas pedal.
Diagnosis:
- I assumed it was my rear diff mount, the big on that everyone replaces with Poly, but when I replaced my stock mount with poly the clunk was intensified.
- Then I replaced the transmission mounts since they were worn anyway. Essentially no change in the clunk.
- Then I got serious and actually crawled under the car to inspect things closely, rather than just throw more parts at it. I was specifically looking for play in CV joints and the rear diff (between ring / pinion). Without going into a lot of detail on how to do this, I was able to feel a bit of play in my driveshaft CVs (both of them). I didn't think the small amount of play would be the smoking gun, but by replacing both CVs along with the support bearing, the clunk was ALMOST gone. Probably 90%. My support bearing and mount looked bad, but not destroyed. I went back under the car and felt some play in the rear axle CVs, and on a whim put the stock diff mount in. Now the clunk is 99% gone. So, the poly rear diff mount was magnifying the driveline play that I had (and still have to a certain extent).
Solution:
To summarize the above, my center driveshaft CVs (1x front and 1x rear) and the driveshaft support bearing solved my clunk.
Car:
Symptoms:
Diagnosis:
Solution:
#26
Car:
Symptoms:
Diagnosis:
Solution:
Car:
Symptoms:
Diagnosis:
Solution:
#28
Im collecting everything to rebuild the driveshaft on my S4. GKN Lobro CV joints and a center bearing. After doing all the engine mounts, trans mount, and zero clearance snub, i still have some thunk in the middle to rear of the car it seems like. Im hoping this will solve it.
Jsmooth65
01-31-2008 01:29 PM
aluminumpork
09-22-2005 09:01 PM
dcrall
11-01-2001 08:41 AM
