clunking sound w/ turning full-lock, slow speed
changed tre's, cv's are good... what else? would a bad control arm cause this-I doubt it but??? any leads would help
thanks guys
thanks guys
AudiWorld Uber User
Also tie rod ends
you can inspect the joint by looking directly above the tire. If the rubber boot is torn or missing, you should replace the tie rod end (probably do both at the same time). Part are about $80 each and your car will need alignment afterwards.
There is a heavy duty replacement available that is supposed to last much longer.
Just experienced this on my 2009 A8. Vibrations when wheel is cranked and then slowly progressed to vibrations off the line. Transfer case fluid needed to be replaced, looked absolutely disgusting. Flushed three times for effect. Also replaced diff fluid for good measure etc. Sorry to revive an old thread but made an account just on the odds that someone might come across this looking for a solution.
KenA4S4
Wheels & Tires Discussion
12-12-2008 07:55 AM
JacobB
07-30-2007 12:17 PM
DorK
08-01-2006 11:55 AM
AEGA4
11-21-2002 08:13 PM
wws03
08-19-2001 05:23 PM
