Code help...
OK just replaced the flex plate put the motor back in the car after I drove it about 20 mins. I got these codes..
P1602 - Power supply (B+) terminal 30:low voltage Sporadic: ( I think thats my batter voltage low.)
P1624 - Mil request signal: active. Sporadic: ( don't know what that is..)
P1136 - Bank 1 Mixture adaptation (add): system too lean. ( don't know what that is)
any help would be great.
Keeper of the Cash
Clear the codes and see which ones return. The first one is because you disconnected the batter, the second one means it turned on the MIL, the third could mean a lot.
Post actual VAG codes if you can.
Those are the actually codes from my boy's X431 DIAG LAUNCH....
CODE001:
18010 P1602 Power supply.
CODE002:
18032 P1624 Mil Request
CODE003:
17544 P1136 Bank 1 Mixture.
Cleared all of them.. going to drive the car in a lil bit ..
CODE001:
CODE002:
CODE003:
JJCNSX
02-03-2005 06:30 AM
