code p1545 help
code p1545 help
Ok just got back form pulling the codes from my 98 a4 2.8q 5v. I also just replaced all the vacuum lines (the one from the fuel pressure regulator was pinched off) my MAF and TB are new.
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 142240km/88383miles
Address 01: Engine Labels: 078-907-551-AHA.lbl
Part No: 4D0 907 551 AH
Component: 2.8L V6/5V MOTR HS D02
Coding: 06201
Shop #: WSC 91590
1 Fault Found:
17953 - Throttle Valve Controller: Malfunction
P1545 - 35-00 - -
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 M
Component: ABS/EDS 5.3 QUATTRO D31
Shop #: BB 24302
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 D
Component: A4 KLIMAVOLLAUTOMAT_D75
Coding: 04160
Shop #: WSC 06335
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags Labels: 8D0-959-655-AI7.lbl
Part No: 8D0 959 655 M
Component: Airbag 7 Audi 0502
Coding: 00104
Shop #: WSC 06335
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8D0-919-xxx-17.lbl
Part No: 8D0 919 861 E
Component: B5-KOMBIINSTR.UN4 D06
Coding: 02362
Shop #: WSC 19411
Part No: IMMO
Component: IDENTNR: AUZ8Z0W4210506
IMMO-IDENTNR: AUZ8Z0W4210506
1 Fault Found:
00771 - Fuel Level Sensor (G)
29-10 - Short to Ground - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D06
Coding: 16140
Shop #: WSC 06335
5 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06335
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186 A
Component: Radio D02
Coding: 00201
Shop #: WSC 06335
End ---------------------------------------------------------------------
So I cleared the codes, and tried to do a TBA but it came back (0.0) (26.5) (idle) (ADP ERROR) Can someone give me a clue what direction to go next ?
Where does the readiness (0110 1101) come into play ? Do I need have everthing pass to do a TBA ?
Coding: 06201
Shop #: WSC 91590
1 Fault Found:
P1545 - 35-00 - -
Shop #: BB 24302
Coding: 04160
Shop #: WSC 06335
No Faults Found
Coding: 00104
Shop #: WSC 06335
1 Fault Found:
Coding: 02362
Shop #: WSC 19411
Part No: IMMO
1 Fault Found:
Coding: 16140
Shop #: WSC 06335
5 Faults Found:
35-00 - -
00955 - Key 1
00956 - Key 2
Coding: 00101
Shop #: WSC 06335
Coding: 00201
Shop #: WSC 06335
WECoyote-SuperGenius
09-10-2006 12:40 PM
JustAdam
08-08-2006 05:16 PM
nhkayalker17
09-30-2005 03:51 PM
