compatability with mix matching clutch and flywheel...
ok, so i use to run a Ko4 kit and AWE's stage II kit with 12lb lwfw. keep in mind that this was before they started using the southbend clutches, etc. IIRC.
so now, im running a T-28 and the clutch kit is no longer holding this power.
after doing some research, ive decided to purchase a Spec stage 3 clutch. my question/concern is .....will this new clutch work with the current flywheel that i have from AWE?
i hoping so, so that i dont have to purchase another flywheel.
if so, should i be concerned about it being worn down, etc?
any advice will help before i pull the trigger on the purchase monday morning.
just think, im about to dump more money into the car (clutch) just so i can sell it.
You already have the lwfw, why would you buy another one?
Unless I'm mistaken, you could buy just the clutch, right? S3 listing for $625, s2 for $499? I'll call first thing Monday if you'd like to know, give me a call.
Rub-ISH (Brandon)
15
06-23-2005 05:53 PM
andrew.tt
9
01-15-2005 06:31 AM
mAd1(gt3071r)
09-14-2004 05:56 PM
Greyhound Guy
09-16-2003 02:48 PM
Shoe
07-19-2002 06:18 PM
