Compressing rear brake caliper pistons
#11
GreenA4, dont quit on it. open the reservoir! no handbrakes! you can do it!
#12
...approx. $10.
<img src="http://pictureposter.audiworld.com/116/brake_piston_tool.jpg">
#14
I spent the better part of a week screwing around with mine. Unfortunatly I tore the rubber and had to replace the caliper. list 280.00 but zzmotors found me a new one for 165.00 after buying the cheap tool and no luck I took it to a mechanic and he put the caliper in a vise and while turning the piston with one of the cube things on a ratchet and conpressing with giant channel locks it went right in. Major point is to get it secure(vise) and then try these things BE CAREFULL with the rubber part. one pin hole and you are shot.
hope this helps
hope this helps
#15
the risk of puncturing the dust boot. Put it on a medium ratchet extension, and put some muscle (or an impact gun) into it. Dont forget to crack a bleeder to let the dirty fluid out, no need to push it upstream..
#16
i used a key for a grinder disc . worked great on a 2006 audi a4, along with a g clamp, but I was able to push it in and screw it with the key, clockwise, hope this helps someone else. of to do the other side now
Ragdoll
02-13-2008 01:47 PM
s4florida
14
08-20-2005 04:13 PM
KillerBudgie
05-20-2002 01:26 PM
DocWyte
02-26-2001 06:23 AM
