Coolant Flush and head gasket problem
Old 02-22-2007, 07:11 PM
  #11
New Member
Leonic's Avatar
Default Re: not head gasket, VC gasket maybe...
They gave an estimate for $1,600
  #12
Ertman's Avatar
Default sounds like a busted heater core to me...
ask them how they tested for exhaust gases. The test most likely used will only point them in a certain direction, does not automatically say "blown head gasket".<ul><li><a href="http://www.arrowheadradiator.com/head_gasket_or_combustion_leak_test.htm">leak tester</a></li></ul>
Old 02-22-2007, 07:13 PM
  #13
Ertman's Avatar
Sounds about right, I don't have access to "Mitchell's" right now.
Old 02-22-2007, 07:47 PM
  #14
New Member
Leonic's Avatar
Default Could it be related to flushing of the coolant?
All of these happened after flushing? What could be the cause?
Gurgling sound under dash?
Then low coolant, and now overheating.
Old 02-22-2007, 08:50 PM
  #15
New Member
Leonic's Avatar
Then low coolant, and now overheating?
Anyway thank you guys for your help.
Old 02-23-2007, 02:33 AM
  #16
Ertman's Avatar
Default The gurgling probably came from the flush...
sounds like they left air in the system.
Old 02-23-2007, 02:50 AM
  #17
Tech Guru
4Driver4's Avatar
"Can I use k&amp;W block sealer for a while for short distance driving?" No.
Old 02-23-2007, 02:56 AM
  #18
Jretal's Avatar
Default i have 153k on an original set of HGs on my car...
they should not go out ever 40-50k unless you're doing something retarded...
so yeah, not even close to being correct on that one
To Leonic... do a compression test and a leak down test before doing the HG. Make sure there is a drop in pressure... or if it blows air into the coolant system.
The gurgling is air in the system. How many times did you refill the reservoir? There's a chance they're not fully bleeding the system (which if fully drained takes a bit to get all the air out of the system)
If not, are you smelling any burning coolant in the cabin of the car? possible wetness on the floor around the tranny hump under the dash? If that's the case, maybe the heater core went out... just a thought.
Old 02-23-2007, 04:54 AM
  #19
AudiMick's Avatar
Sounds like they didn't bleed it right the first time.
Old 02-23-2007, 06:12 AM
  #20
Joey T
Guest
Posts: n/a
Default They did not bleed the cooling system correctly, it overheated the engine and cracked the head
or blew a head gasket.
Blow head gaskets *WILL NOT MAKE COOLANT MIX WITH OIL*.
They should, but won't take care of the repairs.
I didn't see.. what engine?
Quick Reply: Coolant Flush and head gasket problem
