coolant/oil temperature not rising
I did a quick search and didn't find the particular problem. Maybe someone can point me to a relevant tech article / thread?
The vehicle is a 1999 a4 2.8 5-spd quattro with 130k miles.
The problem is that as it's gotten colder, my coolant temperature gauge barely rises. Same with the oil temp gauge. Even after 10+ minutes of normal city driving.
Heat works (takes about 5 minutes to blow hot air). External temp gauge seems accurate.
During the summer (when I first got the car) the coolant temp rarely exceeded 1/4. However I do remember seeing it at the 1/2 point on occasion.
Just to clarify, now, the coolant temp moves, but imperceptibly. In the last couple of months, I don't remember it moving more than a couple mm.
What should I do? many thanks in advance
if you leave your car idling for several minutes especially after 10+ mile drive will the coolant temp gauge go to the middle? Just wonder if your thermostat is stuck open too or if that could be the problem. FWIW, I'd replace both CTS as already mentioned and the thermostat if they are still original at 130K not to mention a bazillion other things.
SandMcars
Audi Original "S" Cars
04-30-2008 06:02 AM
pac1085
01-16-2007 02:50 AM
