Coolant temp engine code
I got a code that keeps coming up saying I have a malfunction in the coolant temp circuit. Is this most likely the temp sensor? If so where is this sensor located?
Thanks
Thanks
Multifuction coolant temp sensor(F76). It's on the water pipe under the idle control valve. You may have to remove intake manifold to gain access to it.
Rear view
http://www.12v.org/engine/index.php?...n=cl&view=rear
Top view
http://www.12v.org/engine/index.php?...n=cl&view=cool
Note: The coolant temp sensor(G62) which turns on the AUX fan is located in the lower left of the RAD. This picture shows the previous version of the 12v V6 engine. I just installed new head gasket and didn't see the coolant temp sensor there as shown in this picture.
Rear view
Top view
I am looking at the pipe behind the engine and i dont see that sensor there either. The pictures show it just where the pipe goes to the head next to the bleeder. Are there any other possible locations?
There are 2 coolant temp sensors
1. Multifuction coolant temp sensor(F76). It's on the water pipe under the idle control valve. This is the problem one as it communicates with the ECU. Just took a look and its not visible but, its located under Idle control valve and Intake manifold.
2. Coolant temp sensor(Thermoswitch)- Located in the lower left of the rad. Turns on the AUX fan if Temp goes above 91C etc... The picture below has the wrong location for this sensor.
Rear view
Rear view
It needs a few warm up cycles to clear on it's own.
There are two sensors in one assembly there are (2) pins for each circuit.
Since your gauge isn't working . You have a bad connection or a bad sensor.
Vag.com can read ECU temp and gauge temp.
The other device in the radiator is a thermostatic switch for the fans.
I have cleared the code since I changed the sensor and it came back on. I hope that maybe the connector is bad, ill mess with the connection a little bit and try to get it working. Its not overheating, and the heat is working fine so at least its still drivable. Thanks for the help.
carl viking
40
07-12-2024 02:45 PM
ECS Tuning-Audi
09-03-2015 12:45 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
