crack on dohc cover near oil cap
how bad is that, what makes that happen and what can been done?
i don't use more than 4rpm. 5w30 synthetic, premium fuel. recently flushed out green coolant with pink g11 and have lightly used fuel infection cleaner for about thousand miles.
96 a4 2.8 175k. 5spd.
thanks for any info.
a
a
By the way, 4rpm is the slowest idle I've ever heard of. And G11 coolant isn't pink. But to your question: That valve cover looks different than the ones on my '96, but that cracked part looks like plastic trim, in which case there isn't any need to fix it at all. But you might clean it and try epoxy adhesive if it bothers you.
AudiSport44
18
01-19-2006 05:57 PM
