Crank pulley drive sprocket bolt is KILLING me!
<center><img src="http://pictureposter.audiworld.com/11669/crank_pulley.jpg"></center><p>I am trying to get the crankshaft out of this motor, but the 19mm drive sprocket bolt wont budge.
Any ideas? I can place almost all my weight on the breaker bar and nothing happens except the engine stand acts like its about to collapse.
It's not reverse threaded is it? I have also soaked it in WD-40 but nothing else ( no PB blaster yet).
I am laying on the 1/2" breaker bar you see in the picture. I am going to aquire a "cheater" bar at Lowes later.
remove it is with and impact wrench. I left the gear on my auto crank for you, because I didnt feel like taking it to the autoshop to use th eimpact wrench
I followed Tom's advice about not taking it off. My front seal carrier had 2 pins the hold it square, so I had to "carefully" remove the seal from the pins while lifting out the shaft. It was nerve-wracking because I would hate to scratch the main bearing journals on this crank because visually they look great ( haven't measured them ).
P.S. This method leaves the front seal carrier on the shaft to be removed later.
