crank shaft holder 3242 where does this go i need a refrence to this photo
<center><img src="http://pictureposter.audiworld.com/32880/crank_shaft_holder3242.jpg"></center><p>
Please help !!
this is all the manual gives..
Is the larger nut on the bottom left the oil plug???
Thanks
96 a4 2.8 QM in the middle of a timing belt change...
Please help !!
Thanks
EDIT... Remove the crank position sensor,, it looks to be right above the oil drain as you mentioned
Look for a harness attached to a sensor in that general area, I may be able to get a picture for you later...
Flown
A4 (B7 Platform) Discussion
07-03-2018 12:16 PM
Greg PAW
12v V6 Discussion
12
04-19-2004 10:09 AM
