Creaking & clunking from front end at low speeds; beginning to wander. 94k. Control arms? :-/
A few things to check........
Check your tie rod end boots, if they aren't torn and have no play, lube the swaybar bushings. Even my OEM rubber ones make strange noises if they don't have some grease. Not sure where you live, but the cold weather makes it worse here.
Worth trying before you drop big bucks. If the problem remains, it could be control arms. Are yours original?
I'm swapping wheels later tonight, so I'll pull & tug around while I'm under there. (m)...
Yup - it's cold here. I'm a 1/2 hour north of AWE - I saw your car there at the last dyno day.
Thanx. :-)
Thanx. :-)
Tie Rod **END** is usually the culprit. Those are $39 each at ECS Tuning.
No need to replace the whole tie rod usually, as it's just the ball joint on the end that typically fails.
Andy
Andy
~$50 each at IMPEX for the whole tie rod. I'd suggest replacing it all, because...
You'll find that the ends corrode to the rest of the tie rod, and are a NIGHTMARE to break loose. You'll save a ton of labor if you just replace the whole tie rod. Any car with bad ends probably has enough miles on it that it's certain to have a corrosion issue. In fact, my frame/alignment guy stopped doing just the ends on Audis. He said the problem is so widespread, that they will only replace the tie rod as a complete unit.
