Cyl. 4,5,6 Misfiring.... How come???
Old 10-02-2006, 06:43 PM
New Member
My94A4Quattro's Avatar
Default Cyl. 4,5,6 Misfiring.... How come???
had timing redone after it was done improperly. After that i replaced the coil pack and plugs. DID NOT REPLACE WIRES. The car is throwing Misfire codes on 4,5 and 6. What could this possibly be?
I was first told that it is most likely the wires... and then told again by a few people that maybe the valves.
Old 10-02-2006, 07:00 PM
Banned
4Rings::G2 boosted::'s Avatar
sounds like your driver's side cam is still off by a tooth or two
Old 10-02-2006, 07:02 PM
xdriver's Avatar
all plugs properly gaped AND torqued? could be that simple.. never know
Old 10-02-2006, 07:12 PM
New Member
Default All plugs are properly gapped and torqued. Car was re-timed and was dead on.
I am going to get new wires later on this week and go from there.
Old 10-02-2006, 07:31 PM
qfrog Ti20's Avatar
Default Did you release the cam gears from the camshafts?
The belt has to be tensioned manually before you set the torque on the camshaft bolts. The cam gears should be floating which allows for the belt length between the gears to be tensioned like the rest of the belt.
Old 10-03-2006, 02:31 AM
Head Cat Herder
Kris Hansen's Avatar
That won't cause a misfire though, being off a tooth or 2...
Old 10-03-2006, 04:41 AM
Banned
I disagree, one cam off timing can definately cause misfires
Old 10-03-2006, 05:34 AM
Head Cat Herder
How so?
Old 10-03-2006, 06:38 AM
Carson (K03x2)'s Avatar
Default This is true
I did a cam adjuster on a Passat 30V back when I worked for VW and one of the cams was one tooth off...the car would misfire at idle but as soon as you stepped on the gas it went away.
Old 10-03-2006, 03:04 PM
New Member
Default My car misses at idle and...
it sounds like a spark knock or a lifter tick. It gets louder as you step on the gas.
Quick Reply: Cyl. 4,5,6 Misfiring.... How come???
