is datablock 031 the correct block to monitor the O2 sensor?
upon request from a friend:
Monitor the O2 sensor for me when you floor it. If the voltage drops below 0.75 volts, you may be going lean. At idle and part throttle, the voltage should dither between 0.1-0.8 back and forth, but a full throttle, you should be seeing closer to 0.80-0.90 and holding. That means plenty of fuel.
it's a long file, so give it time to load. There all types of driving in there. Normal street driving, WOT, freeway. etc.<ul><li><a href="http://www.jother.com/misc/o2.htm">block 036 log (with RPM's and boost)</a></li></ul>
pipebender
05-26-2008 01:23 PM
audiquatro75
Audi Original "S" Cars
01-29-2005 01:04 PM
got_root?
Performance and Tuning
03-01-2002 11:35 PM
got_root?
02-28-2002 05:32 PM
