Dear Audi, why did you have to place the quattro fuel filter in that location!?!?
AudiWorld Expert
I must say, I've never been as frustrated working on my car until changing the farking fuel filter. I used Rob@audiworld's write-up and it was very helpful. The only problem was that Audi uses a square nut on the back side against a plastic clamp. I was able to use a T-40 torx (6-pt) socket in place of the required 12 pt to loosen the screw. The problem was that the square nut decided to turn loose with the screw! Metal against plastic and metal won. I must have spent over an hour turning while trying to hold that stupid nut in before I turned postal and started prying the band apart. After about 2 hours wasted trying to be civil I pried the plastic clamp apart. The back nut came through the other plastic clamp end and out came the filter. The holes were enlarged and I used a ziptie in place of the old screw. It's holding quite well along coupled with the tank reattached. So far no leaks detected. I used new banjo washers and torqued down the fittings as snug as possible. I can't believe I consider this more of a PITA than a TB change. BTW, I did this on jack stands and although a lift would be ideal, it's more than doable.
AudiWorld Expert
I think a few guys have just cut that clamp apart and ziptied it. I tried to save the clamp before getting frustrated to the point I pried that thing apart. That plastic is incredibly durable! If you get to the stage where you can't get the screw totally out but decide to pry it apart, you may wind up in the same situation as me and can use a ziptie in place of the screw/nut.
AudiWorld Expert
I got back and remembered I had the fuel filter waiting to go in the Audi so I switched cars to work on. I'm glad I got it done but it really tested my patience. I drove around Princeton to test the car out. No leaks detected so far...
AudiWorld Expert
:-p
How much did they charge you? If it was $50 including parts, I'd pay for it. If it was $100 I'd rather go through what I did. I'll be able to change mine easily from now on...
Found cheap Victor tire gauge for pressure bleeder.The end screws off and has a pipe thread beneath.I tapped the hole on my sprayer and installed the gauge.They were even in different colors.My bleeder is now finished and I only spent $22 TOTAL.Sprayer tank was $12 at Sears,already with clear hose.Next job for me is the fuel filter and test my bleeder.Hope my filter is easier.
