Did the Timing Belt, Water Pump, and snub mount, added the coolant back in with a little water. more
Old 01-12-2003, 08:20 AM
Senior Member
simply J's Avatar
Default Did the Timing Belt, Water Pump, and snub mount, added the coolant back in with a little water. more
I am getting a bad vibration on the steering wheel, and the car is overheating. ANY IDEAS???
Old 01-12-2003, 08:31 AM
skabaru's Avatar
Default the snub needs to be adjusted... that is easy... as for the overheating..
did you use the right coolant? (shouldn't overheat even if you didn't)
are you leaking coolant?
are you full of coolant? you need to add coolant, run the car a little, add more coolant, etc.
Old 01-12-2003, 08:33 AM
Bryans12v's Avatar
Default He might have some air in there...
I went through the same thing on my 2.8 when I had it all out the last time.
Dude, try bleeding the coolant from the hose going through the firewall.
Old 01-12-2003, 08:36 AM
skabaru's Avatar
good call
Old 01-12-2003, 08:38 AM
Senior Member
simply J's Avatar
How do you adjust the snub?
Old 01-12-2003, 08:39 AM
Bryans12v's Avatar
Default About the overheating issue..
Do this.
Thank Yippers. <ul><li><a href="https://forums.audiworld.com/a4/msgs/1030749.phtml">Here...</a></li></ul>
Old 01-12-2003, 09:07 AM
Senior Member
simply J's Avatar
Default I don't want to sound like an idiot but I can't find it still
also when driving the car, the heat doesn't work, it just blows out cold air.
Old 01-12-2003, 10:07 AM
Innovator's Avatar
Default By taking it out and getting the DTS.
JK, but the DTS does work much better and has many other benefits ofer the Snub.
Member
Yippers®'s Avatar
Old 01-12-2003, 10:11 AM
Member
Yippers®'s Avatar
Default The Bentley's picture in the link Bryans12v posted is facing the firewall and just below and to the
left of the coolant expansion tank. One thing I failed to properly note in that other thread .. you'll want to loosen the coolant expansion tank cap when you raise it up the ~4 inches. Otherwise the coolant won't flow into the system to displace the trapped air.
Quick Reply: Did the Timing Belt, Water Pump, and snub mount, added the coolant back in with a little water. more
