Directional Tire on Spare Rim??!??!
Old 08-05-2001, 10:26 AM
wishbone's Avatar
Default Directional Tire on Spare Rim??!??!
So I'm trying to figure out WHY audi would put a directional tire on the spare rim? Maybe I'm missing something, but would it be considered safe to use a directional tire in the opposite direction for which it was intended?
Old 08-05-2001, 10:27 AM
Junior Member
Bucket's Avatar
It's fine except in the rain.
Old 08-05-2001, 10:33 AM
Zed 2.0's Avatar
Default Well, not really. The directional tredding is designed to add grip and stability...
I wouldn't want to throw a directional tire that's on backwards hard around a corner.. you'd probably lose all your traction on that wheel. Plus, it may make for generally uneven and quirky driving.
Old 08-05-2001, 10:34 AM
wishbone's Avatar
Hmm.. Bad move on Audi's part then.. what kind of "spare" is that?
Old 08-05-2001, 10:38 AM
bugbbq's Avatar
it's one that you only use when you need a "spare"
Old 08-05-2001, 10:41 AM
wishbone's Avatar
Yeah great.. As long as I can manage to only blow out on one side! =P
Old 08-05-2001, 10:51 AM
Elder Member
Dead's Avatar
Default Use it to get you somewhere to have the tire fixed or replaced.
You'll be fine.
Old 08-05-2001, 11:00 AM
wishbone's Avatar
Default I still think that loses the point of having a full spare...
But I guess my point is, that if audi is going to go to the trouble of giving me a full rim spare, they could at least make it a functional full time tire that could actually be used to replace all four instead of just two of the current wheels. *shrug* call me crazy I guess..
Old 08-05-2001, 12:36 PM
Junior Member
Bucket's Avatar
I disagree. The tread pattern is only useful for water. That's why people race on slicks.
Old 08-05-2001, 02:15 PM
boki-san's Avatar
Default if you're talking about the full size spare, ....
firstly, the idea is that you ideally want all four corners carrying the exact same tyre. audi typically chooses performance tyres that are "directional." this "directionality" with regards to how a performance tread grips, is minimal. the main reason these tyres are labeled with a rotating direction, is that after many miles of use, the belts and guts of the tyre take a "set", due to acceleration and braking forces. to change the rotating direction after they've taken a "set", would oppose the current "set", and could cause de-lamination, and possibly catastrophic failure. but to use an unused tyre against it's rotating direction would be totally safe and grip-wise, virtually unnoticeable. i am not a tyre expert, i can't even spell it correctly. tyre experts, correct me if i'm wrong.
Quick Reply: Directional Tire on Spare Rim??!??!
