Disconnecting the airbag
I'm changing the turn signal, headlight, cruise combination switch. After disconnecting the battery, waiting 30 minutes, and unbolting the driver's airbag, what is the correct way to disconnect the airbag? Does the plug on the wiring snap out from the back of the airbag unit, or must I unplug it from the steering column end and also unplug the wires from the steering wheel which trigger the horn? I'm not sure if the wires are supposed to unplug from the back of the airbag and I dont want to break it, so thanks for reply from those who know these things better.
Just leave the ignition off for 30 min before starting.
The clock spring wires plug directy into the back of the bag. Unplug there.
meem
9
10-14-2007 06:33 PM
tipo158
09-25-2006 09:43 PM
