Do any of you see any problems running 195/65-15 snow tires instead of 205/60-15?
#24
I'd still run that size if I didn't upgrade to A8 rotors requiring 16". Now I run 205/55/16
Suggesting that it's hazardous to run 195/65/15 is rediculous.
#25
I know you run taller tires, but it's not necessary. I ran 195/65/15 for two winters and they cut through the snow better than any 205s I've had since then, including much more aggressive compounds and tread patterns.
#26
My post above this one said "No problem" to the 195's also.... maybe you weren't responding to me... going 1 or two sizes up or down is not "going skinny"... a 20mm diff (2 to 3 tire sizes) is less than a finger width of tire and will not affect performance in this situation.
#27
According to the following sources, they show 195/65/15
Tirerack.com when you put in 97 a4 1.8t quattro
my 97's manual
my 97's sticker in the gas door
when i bought my 97 with 50k miles on it, it had the original tires which were 195/65/15
my 98 gas door sticker also said 195/65/15
so does my other 98 parts car which also has 195/65/15 on the stock wheels.
I have never seen 205/60/15's on a b5 a4 1.8t. maybe its only on the v6's or sport packages or something?
my 97's manual
#29
If they're the same size or close to your oem tires, run the same pressure. Over inflation will cause irregular tread wear, under inflation will affect fuel mileage.
