do boost gauges connect to your wastegate?
the boost readings your gauge can handle. That would give you a reading of what the turbo is putting out all the time. You want to put the boost gauge off of the intake manifold so you read it in there only.
The best one I found is the HKS EV4 which will learn the boost curve of the turbo. But these should only be used with a larger turbo that can hold a set boost to redline.
alibaba
03-21-2005 01:59 PM
BlackA6
11-22-2002 09:40 AM
holychild666
02-25-2002 03:31 PM
