do i need high heat clear coat when doing the the calipers?
if you use folia-tec or g2, no. if you use spray paint, or high temp paint
that isn't in a kit, yes. well actually you don't need it, but IMHO it would look better with a couple clear coats over it.
if you use folia-tec or g2 and put a decal on top, you need high-temp clear coat as well.
here's a link to my boxster calipers painted with the folia-tec system.
<a href="https://forums.audiworld.com/a4/msgs/1958524.phtml">https://forums.audiworld.com/a4/msgs/1958524.phtml</a>
custom decals by golfrsi over on the s4 boards. Looks damn good.
Re: do i need high heat clear coat when doing the the calipers?
Regular paint is probably going to work just fine. They don't get THAT hot. High heat paint can't hurt though. Why clear coat? Why not just the colour you want and forget the clear coat?
Cheers,
Cheers,
es4uerzo
19
08-18-2004 03:41 AM
Cromom
NorCal Discussion
08-21-2003 09:33 PM
Brian@P.O.G.
07-03-2001 10:55 AM
