Do injectors and the fuel pump run on the same relay??
My car wont start, and after quite a bit of trouble shooting, i determined the fuel pump wasnt running. So I hardwired the fuse to the pump to the battery and it went on, which leads me to believe the relay for the fuel pump is bad. While the pump was running (hardwired to the battery) I tried starting it, but to no avail. Then, I relaized that the injectors and the pump probably run off the same relay, which would make sense. Is this true? Do they run on the same relay or am I totally off base?
thanks
-Steve
thanks
-Steve
Yeah I've been having the same problem. Sometimes it doesn't want to start. And when it does start, it dies right away. Then sometimes it starts fine. Please help me out to resolve this problem.
Thats not the problem im having, but goodluck. My question is- do the fuel pump and injectors run on the same relay?
Ertman
10-02-2008 12:41 PM
DoraBug
05-10-2005 04:17 PM
