does anybody find the cruise control to be "flaky"?
I've used the cruise for two trips since we bought the car last month. It takes a holds a speed just fine but the decell, accell and resume functions are glitchy at best. User Error? or **** design?
I've had mine replaced at least 3 times under warranty.
It doesn't work now, but I think the current "problem" is because I'm chipped, and IIRC, you can't have CC with a chip.
It is most likely the switch. It is a common problem with VW/Audi CC. Get the switch changed...
... the switch is on the turn signal stalk and this is also in the same module as the headlight switch. It won't be a cheap part.
Kirk
Kirk
Hmm...
Maybe I made that up. Or maybe it wasn't available when I bought my chip, because it's been 2.5 years now, I think. I can't remember. I should probably call and ask, but I'm just too lazy :/
With a VAG tool, you need to go the the engine control module...
... and then go the the login option and enter a certain code. This new code will enable the CC for your car. You can do this with a VAG-com. As for what code to put in, I can find it somewhere if you cant.
Kirk
Kirk
