does anybody know the flashpoint of conventional oil
I went onto the mobil 1 web site to try and figure out what viscosity oil I wanted to get and noticed the flshpoint numbers listed. I was just curious to know the difference. IMO the main reason to use a synthetic oil is because of the extreme temps in a turbocharged engine.
AudiWorld Expert
Some additional reasons to use synthetic:
- it flows more easily when cold (at engine startup), so that your engine gets the much needed lubrication faster. BTW, there are no 0w grade mineral oils in the US.
- it stays "clean" longer, so you can extend your oil change intervals.
- it does not coke in the turbo cooling lines as easily as mineral oil (so I've heard).<ul><li><a href="http://www.mr2.com/TEXT/OilFacts.txt">http://www.mr2.com/TEXT/OilFacts.txt</a</li></ul>
AudiWorld Expert
Scroll down to about 1/3 of the page.
Note: I cannot attest to the correctness of this source, nor to the affiliations of the author.<ul><li><a href="http://www.mr2.com/TEXT/synth_oil.txt">http://www.mr2.com/TEXT/synth_oil.txt</a</li></ul>
they had specs as well. Since Quaker State is considered total crap I figured that would be a good comparison
silvertiger
04-19-2001 02:05 PM
