Does anybody know if '82 Porsche 911 SC is fuel injected or carburated?
If anybody can help me out, my father and I would appreciate it. Tonight his Porsche quit running, here are the symptoms. While he was driving the tachometer was going crazy. It was going between 0 and 7000 RPM. Just before he shut it down, the windows and sun roof were closing very slowly as if it didn't have enough battery power. Fearing that the battery was dead, he turned it off and was unable to restart it (acted like there was no battery power). He came back 2 hours later and it started right up and he drove for about 3 miles and it died again. He let it sit for a while and then tried to restart it again. It would turn over, but never fire. They then attempted to jump start but to no avail. What does this sound like to you guys. Bad electrical connection, alternator, battery.
Thanks.
Thanks.
I owned a 1981 911SC. In answer to your question, the 911SC is fuel injected - it uses a mechanical system called CIS, continuous injection system. It sounds like your father's problem could be an alternator or the voltage regulator. Have him (or someone), if they can get the car running, test the voltage going to the battery. If it's above 14V, the voltage regulator is likely bad. If it's below about 11V, it's probably the alternator on the way out.
It may also be some other electrical problem, like bad plug wires. When an engine isn't running, 95% of the time it's either gas or spark. If you've got gas, then I would say it's something wrong with the electrical system.
Small Town Terrorist
Audi Original "S" Cars
02-06-2005 01:43 PM
TwoTrey
11
06-10-2004 11:39 AM
Zzak
01-30-2004 08:55 AM
