does anyone know how much 4 qts of oil would look like on the dipstick?
i think the DAMN DEALER put in 5 quarts of crap oil, and took my 4 quarts of mobil 1 synth. the oil line is way above the top kink!
AudiWorld Expert
hard to say...
depends if the tech waited for all the oil to drain completely or not. Assuming he did wait quite a while, it should be just a little over the max level on the dipstick.
Also, be sure to check your oil level on a level (!) surface when the engine is cold.
so from bottom bend in the metal to the top bend, its 1 quart?
do you know if the whole thing is the same scale...ie, if i measured the distance from bottom to top as being one quart, could i use that as a scale for any oil above the line?
