does anyone know what offset works for 01 s4, need space to clear porsche caliper...35mm?
im getting 18 or 19" rims but i need to know what offset i have to get. i think the factory offset is either 32 or 35mm
Of course you can add spacers to increase the clearance between the center and the caliper. This decreases effective offset, so you would want to find a wheel with a corresponding increased offset to keep the tire clearances and rim centered. For instance if you needed a 10mm spacer to clear a given wheel design and that wheel width is 8", given the normal desired offset is 35-38mm, you would want to get the wheel with a 45mm offset.
onewickeda6
Wheels & Tires Discussion
04-07-2008 08:59 AM
B56
02-11-2008 04:30 PM
jasyn³
06-16-2003 07:25 PM
