does my diagnoses of a bad wheel bearing sound correct?
a couple months ago i had a freak wheel malfunction where a lug bolt wasn't tightened all the way(not sure who was at fault on that one), but anyway, the wheel started to flop around... which i'm sure wasn't good for the wheel bearing.
anyway, the past couple days there's been a bit of noise coming from that wheel well, right rear. kind of the same noise that came from the flopping wheel, whirring kind of noise.
it kind of goes away around right hand corners, and over bumps, like when weight is lifted from that wheel...
also the other thing that makes me think wheel bearing, is yesterday i swapped to my summer wheels, and when i took the wheel off the right rear hub the lug bolts were quite hot to the touch(i was thinking bad bearing, more friction, more heat... right?)...
so anyway, sounds like bad wheel bearing maybe? i'm almost at 78,000 and none of the bearings have been replaced. should i change both the rear ones while i'm at it? or maybe all 4?
sounds like a wheel bearing...
as for changing them all at once I personally don't think it's necessary. Just change them as they go bad, could be next week or 10k miles from now.
thanks
for some reason i kind of like replacing things as a whole... last summer i had to replace the rear brake pads and rotors, so i did front/rear rotors and pads with a fluid flush(even though the front brakes probably would have lasted a while longer). just for example.
laterskater
05-23-2005 07:30 AM
SpeedyDTP247 CQ+UrS4
02-01-2005 04:18 AM
audijim113
10-22-2004 08:04 PM
Senna4Life
04-30-2002 01:02 PM
