Does a VAG-COM have a code for an exhaust leak and
with the ECU. Most likely though, it's leaking post cat, so I wouldn't worry.
to tell the ECU what's going on. IF you have a leak pre cat, the o2 sensor after the cat will not be getting accurate readings, thus your car's ecu is getting false info, and therefore the engine probably runs like poo.
So if the cat broke at the flange to the turbo (as it commonly does on the 1.8T)....one would expect to be running very rich, yes? Not only did my car run like poo when mine broke but it also guzzled some gas....figured it was running rich.
Andy
Andy
98Quattro
07-22-2008 09:46 AM
Bolo
04-20-2008 04:08 AM
