Doing brake pads tommorow - buddy says there is no point in renting that tool - says Needle nose
plyers are all we need.
I've never done the brakes on this car yet. Should I stop by Autozone tonight and rent the tool? Just to have it if need be?
changing rotors in the rear?
I'm replacing the rotors on the rear on sat whats this about a tool? dont I just pull off the calipers and take it off and push the caliper piston back in and put the pads back on?
anyone know a good place to get the alan wrench sockets to take the calipers off and what size I need?
Hmmmm. I had the cube tool, and to be honest I wish I had the proper piston-pusher tool. It was awkward to hold the caliper in one hand and then to push as hard as you can while turning the ratchet in the other.....then again, I'm weak. Gjaime picked it up and took care of it for me....he made it look easy ;-) I say just rent it if you can, might save you some effort. Good luck
Andy
Andy
