Door Sag
I have a 1998 A4 2.8 Quattro that the drivers side door has begun to sag. As soon as I lift the door handle to open the door it drops about 3/8". This make the door not align correctly when closing and has begun to rub the top corner of the window frame against the B pillar. Is there an adjustment to the hinges or some advise as to where to begin looking for the fix?
Thanks
Rick
Thanks
Rick
I would check all the bolts on the hinges to make sure they are tight. If you find any loose...you'll need to support the door's weight, and tighten the bolt...then hope it lines up right when you close it. If not, loosen the bolts, and repeat as needed.
Wahhab
Audi Original "S" Cars
08-03-2008 09:37 AM
Kingttr
12-05-2006 08:47 AM
barbos011
01-31-2005 01:27 PM
egp320i
9
07-13-2004 11:48 AM
